Robust Planning of Green Wireless Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current methods dealing with the energy efficient wireless network planning problem require a static model. However, bit rate requirements vary and rise over time, users move around and path gain fluctuates. In this paper, robust optimization is applied to deal with demand uncertainty. We present a robust optimization model for the energy-efficient planning of wireless networks and apply cutting planes to reduce the complexity of the model. Furthermore, a case study is performed to compare the robust formulation to its deterministic counterpart and to conventional network planning.
4-PID2128315.pdf (184.34 Ko) Télécharger le fichier
hal-00643687 , version 1 (22-11-2011)
  • HAL Id : hal-00643687 , version 1
Grit Classen, Arie M.C.A. Koster, Anke Schmeink. Robust Planning of Green Wireless Networks. NetGCOOP 2011 : International conference on NETwork Games, COntrol and OPtimization, Telecom SudParis et Université Paris Descartes, Oct 2011, Paris, France. ⟨hal-00643687⟩
Collections
NETGCOOP2011
78 Consultations
369 Téléchargements
