Numerical Approximation of the Masser-Gramain Constant to Four Decimal Digits: delta=1.819... - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2013
We prove that the constant studied by Masser, Gramain, and Weber, satisfies 1.819776 < delta < 1.819833, and disprove a conjecture of Gramain. This constant is a two-dimensional analogue of the Euler-Mascheroni constant; it is obtained by computing the radius rk of the smallest disk of the plane containing k Gaussian integers. While we have used the original algorithm for smaller values of k, the bounds above come from methods we developed to obtain guaranteed enclosures for larger values of k.
hal-00644166 , version 1 (23-11-2011)
Guillaume Melquiond, Werner Georg Nowak, Paul Zimmermann. Numerical Approximation of the Masser-Gramain Constant to Four Decimal Digits: delta=1.819.... Mathematics of Computation, 2013, 82, pp.1235-1246. ⟨10.1090/S0025-5718-2012-02635-4⟩. ⟨hal-00644166⟩
438 Consultations
0 Téléchargements
