Simulation Based Analysis Of Middleware Service Impact On System Reliability: Experiment On Java Application Server - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Systems and Software Année : 2011
Being a popular runtime infrastructure in the era of Internet, middleware provides more and more services to support the development, deployment and management of distributed systems. At the same time, the reliability of middlewareservices has a significant impact on the overall reliability of the system. Different services have different impacts and different service fault-tolerance solutions have different costs and risks. Therefore, the identification of the services that greatly affect the whole systemreliability is the major obstacle to achieving reliable middleware-basedsystems. In this paper, we present an analytical framework to automatically reason and quantify such impacts when deploying the target system. In this framework, faults are represented by exceptions in modern programming languages; service failures are simulated by software fault injection; reliabilityimpacts are measured by scenarios. This framework is demonstrated on multiple JEE application servers, including JBoss, JonAS and PKUAS. The experiments on two JEE blueprint applications, namely JPS and ECperf, show the feasibility, the applicability and the usability of this framework.
JSS_PKUAS_V3.pdf (769.6 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00644654 , version 1 (30-11-2011)
  • HAL Id : hal-00644654 , version 1
Gang Huang, Weihu Wang, Tiancheng Liu, Hong Mei. Simulation Based Analysis Of Middleware Service Impact On System Reliability: Experiment On Java Application Server. Journal of Systems and Software, 2011, 84 (7), pp.1160-1170. ⟨hal-00644654⟩
Collections
CONNECT TDS-MACS
145 Consultations
410 Téléchargements
