Wind Simulation Refinement: some New Challenges for Particle Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present two new challenges related to the stochastic downscaling method SDM that we applied to wind simulation refinement in \cite{BBCDRS08}. After setting the framework, we introduce the boundary forcing issue, and propose a numerical scheme adapted to Particle in Cell methods. Then we turn to the uniform density constraint raised by SDM and propose some new methods that rely on optimization algorithms.
hal-ecmi2008-final.pdf (112.63 Ko) Télécharger le fichier
hal-00644924 , version 1 (25-11-2011)
Claire Chauvin, Frédéric Bernardin, Mireille Bossy, Antoine Rousseau. Wind Simulation Refinement: some New Challenges for Particle Methods. ECMI 2008 - The European Consortium For Mathematics In Industry, Jun 2008, London, United Kingdom. pp.765-770, ⟨10.1007/978-3-642-12110-4⟩. ⟨hal-00644924⟩
482 Consultations
300 Téléchargements
