Some defective secant varieties to osculating varieties of Veronese surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Collectanea Mathematica Année : 2006
We consider the $k$-osculating varieties $O_{k,d}$ to the Veronese $d-$uple embeddings of $\PP 2$. By studying the Hilbert function of certain zero-\-dimensional schemes $Y\subset \PP 2$, we find the dimension of $O^s_{k,d}$, the $(s-1)^{th}$secant varieties of $O_{k,d}$, for $3 \leq s\leq 6$ and $s=9$, and we determine whether those secant varieties are defective or not.
SecVar_to_OsculatingVar.pdf (197.87 Ko) Télécharger le fichier
hal-00645929 , version 1 (28-11-2011)
  • HAL Id : hal-00645929 , version 1
Alessandra Bernardi, Maria Virgina Catalisano. Some defective secant varieties to osculating varieties of Veronese surfaces. Collectanea Mathematica, 2006, 57 (1), pp.43-68. ⟨hal-00645929⟩
173 Consultations
58 Téléchargements
