Symmetric tensor rank with a tangent vector: a generic uniqueness theorem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the American Mathematical Society Année : 2012
Let $X_{m,d}\subset \mathbb {P}^N$, $N:= \binom{m+d}{m}-1$, be the order $d$ Veronese embedding of $\mathbb {P}^m$. Let $\tau (X_{m,d})\subset \mathbb {P}^N$, be the tangent developable of $X_{m,d}$. For each integer $t \ge 2$ let $\tau (X_{m,d},t)\subseteq \mathbb {P}^N$, be the join of $\tau (X_{m,d})$ and $t-2$ copies of $X_{m,d}$. Here we prove that if $m\ge 2$, $d\ge 7$ and $t \le 1 + \lfloor \binom{m+d-2}{m}/(m+1)\rfloor$, then for a general $P\in \tau (X_{m,d},t)$ there are uniquely determined $P_1,\dots ,P_{t-2}\in X_{m,d}$ and a unique tangent vector $\nu$ of $X_{m,d}$ such that $P$ is in the linear span of $\nu \cup \{P_1,\dots ,P_{t-2}\}$, i.e. a degree $d$ linear form $f$ (a symmetric tensor $T$ of order $d$) associated to $P$ may be written as $$f = L_{t-1}^{d-1}L_t + \sum _{i=1}^{t-2} L_i^d, \; \; \; \; (T = v_{t-1}^{\otimes (d-1)}v_t + \sum _{i=1}^{t-2} v_i^{\otimes d})$$ with $L_i$ linear forms on $\mathbb {P}^m$ ($v_i$ vectors over a vector field of dimension $m+1$ respectively), $1 \le i \le t$, that are uniquely determined (up to a constant).
BBfinal.pdf (152.38 Ko) Télécharger le fichier
hal-00645979 , version 1 (28-11-2011)
Edoardo Ballico, Alessandra Bernardi. Symmetric tensor rank with a tangent vector: a generic uniqueness theorem. Proceedings of the American Mathematical Society, 2012, 140, 10, pp.3377-3384. ⟨10.1090/S0002-9939-2012-11191-8⟩. ⟨hal-00645979⟩
124 Consultations
130 Téléchargements
