Knowledge extraction for improving case retrieval and recipe adaptation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Julien Cojan
  • Fonction : Auteur
  • PersonId : 836380
Valmi Dufour-Lussier
  • Fonction : Auteur
  • PersonId : 874752
Emmanuelle Gaillard
  • Fonction : Auteur
  • PersonId : 765221
  • IdRef : 197149065
Jean Lieber
Emmanuel Nauer
Taaable 4 is a case-based cooking system which is a contestant in the fourth "Computer Cooking Contest", inheriting most of the features of its previous versions as well as adding new ones. Two new features both concerning knowledge acquisition using formal concept analysis (FCA) are proposed this year. The first feature uses FCA in order to enrich the domain ontology (especially the ingredient hierarchy), making the case retrieval more progressive and more precise. The second feature addresses explicitly the adaptation challenge: given a recipe R and some constraints, how can R be adapted. To compute the best way to adapt R, we propose a FCA-based method for extracting adaptation knowledge. These two knowledge extraction processes exploit additional data (73795 recipes) from the "Recipe Source" database.
CCC_definitif_2011.pdf (428.75 Ko) Télécharger le fichier
hal-00646717 , version 1 (30-11-2011)
  • HAL Id : hal-00646717 , version 1
Julien Cojan, Valmi Dufour-Lussier, Emmanuelle Gaillard, Jean Lieber, Emmanuel Nauer, et al.. Knowledge extraction for improving case retrieval and recipe adaptation. Computer Cooking Contest Workshop, Sep 2011, London, United Kingdom. ⟨hal-00646717⟩
281 Consultations
182 Téléchargements
