MSE and FAMIX 3.0: an Interexchange Format and Source Code Model Family - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Software systems exceeding a certain critical size easily become difficult to maintain and adapt. Requirements change, platforms change and if a system does not evolve properly, its usefulness will decay over time. This document presents MSE a robust, scalable, extensible interexchange format and FAMIX 3.0 a family of metamodels to represent source code.
Duca11c-Cutter-deliverable22-MSE-FAMIX30.pdf (257.67 Ko) Télécharger le fichier
hal-00646884 , version 1 (30-11-2011)
  • HAL Id : hal-00646884 , version 1
Stéphane Ducasse, Nicolas Anquetil, Muhammad Usman Bhatti, Andre Cavalcante Hora, Jannik Laval, et al.. MSE and FAMIX 3.0: an Interexchange Format and Source Code Model Family. [Research Report] 2011. ⟨hal-00646884⟩
521 Consultations
1559 Téléchargements
