s'authentifier
version française rss feed
hal-00646912, version 1
Time vs. space trade-offs for rendezvous in trees
Jurek Czyzowicz () 1, Adrian Kosowski (, http://www.labri.fr/perso/kosowski) 2, Andrzej Pelc () 1
(2011)
Résumé : Two identical (anonymous) mobile agents start from arbitrary nodes of an unknown tree and have to meet at some node. Agents move in synchronous rounds: in each round an agent can either stay at the current node or move to one of its neighbors. We consider deterministic algorithms for this rendezvous task. The main result of this paper is a tight trade-off between the optimal time of completing rendezvous and the size of memory of the agents. For agents with $k$ memory bits, we show that optimal rendezvous time is $\Theta(n+n^2/k)$ in $n$-node trees. More precisely, if $k \geq c\log n$, for some constant $c$, we design agents accomplishing rendezvous in arbitrary trees of unknown size $n$ in time $O(n+n^2/k)$, starting with arbitrary delay. We also show that no pair of agents can accomplish rendezvous in time $o(n+n^2/k)$, even in the class of lines of known length and even with simultaneous start. Finally, we prove that at least logarithmic memory is necessary for rendezvous, even for agents starting simultaneously in a $n$-node line.
  • Domaine : Informatique/Algorithme et structure de données
  • Mots-clés : rendezvous – anonymous agents – time – memory space
  • hal-00646912, version 1
  • oai:hal.inria.fr:hal-00646912
  • Contributeur :
  • Soumis le : Jeudi 1 Décembre 2011, 00:48:20
  • Dernière modification le : Jeudi 1 Décembre 2011, 10:47:49
tous les articles de la base du CCSd...
