Towards a Model-Driven Infrastructure for Runtime Monitoring
In modern pervasive dynamic and eternal systems, software must be able to self-organize its structure and self-adapt its behavior to enhance its resilience and provide the desired quality of service. In this high-dynamic and unpredictable scenario, flexible and reconfigurable monitoring infrastructures become key instruments to verify at runtime functional and non-functional properties. In this paper, we propose a property-driven approach to runtime monitoring that is based on a comprehensive Property Meta-Model (PMM) and on a generic configurable monitoring infrastructure. PMM supports the definition of quantitative and qualitative properties in a machine-processable way making it possible to configure the monitors dynamically. Examples of implementation and applications of the proposed model-driven monitoring infrastructure are excerpted from the ongoing Connect European Project.
Génie logiciel [cs.SE]
