Fast Multi-Sequence Shift-Register Synthesis with the Euclidean Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Mathematics of Communications Année : 2011
Feng and Tzeng's generalization of the Extended Euclidean Algorithm synthesizes the shortest--length linear feedback shift--register for \$s \geq 1\$ sequences, where each sequence has the the same length \$n\$. In this contribution, it is shown that Feng and Tzeng's algorithm which solves this multi--sequence shift--register problem has time complexity \$\ONsn^2\$. An acceleration based on the Divide and Conquer strategy is proposed and it is proven that subquadratic time complexity is achieved.
zeh_11_fast_713877.pdf (524.43 Ko) Télécharger le fichier
hal-00647586 , version 1 (02-12-2011)
Alexander Zeh, Antonia Wachter-Zeh. Fast Multi-Sequence Shift-Register Synthesis with the Euclidean Algorithm. Advances in Mathematics of Communications, 2011, 5 (4), pp.667-680. ⟨10.3934/amc.2011.5.667⟩. ⟨hal-00647586⟩
422 Consultations
484 Téléchargements
