Efficient decoding of some classes of binary cyclic codes beyond the Hartmann-Tzeng bound - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new bound on the distance of binary cyclic codes is proposed. The approach is based on the representation of a subset of the roots of the generator polynomial by a rational function. A new bound on the minimum distance is proven and several classes of binary cyclic codes are identified. For some classes of codes, this bound is better than the known bounds (e.g. BCH or Hartmann-Tzeng bound). Furthermore, a quadratic-time decoding algorithm up to this new bound is developed.
isit2011.pdf (345.89 Ko) Télécharger le fichier
hal-00647590 , version 1 (02-12-2011)
Alexander Zeh, Antonia Wachter-Zeh, Sergey Bezzateev. Efficient decoding of some classes of binary cyclic codes beyond the Hartmann-Tzeng bound. IEEE International Symposium on Information Theory (ISIT), Jul 2011, St. Petersburg, Russia. pp.1017-1021, ⟨10.1109/ISIT.2011.6033683⟩. ⟨hal-00647590⟩
624 Consultations
227 Téléchargements
