Global stability analysis of a metapopulation SIS epidemic model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Population Studies Année : 2012
The conjecture of Arino and van den Driessche (2003) that a SIS type model in a mover- stayer epidemic model is globally asymptotically stable is confirmed analytically. If the basic reproduction number R0 ≤ 1, then the disease free equilibrium is globally asymptotically sta- ble. If R0 > 1, then there exists a unique endemic equilibrium which is globally asymptotically stable on the nonnegative orthant minus the stable manifold of the disease free equilibrium.
GMPS-2010-0183R3b-title.pdf (583.52 Ko) Télécharger le fichier
hal-00648041 , version 1 (05-12-2011)
  • HAL Id : hal-00648041 , version 1
Abderrahman Iggidr, Gauthier Sallet, Berge Tsanou. Global stability analysis of a metapopulation SIS epidemic model. Mathematical Population Studies, 2012, 19 (3), pp.115-129. ⟨hal-00648041⟩
242 Consultations
729 Téléchargements
