The averaged control system of fast oscillating control systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2013
For control systems that either have a fast explicit periodic dependence on time and bounded controls or have periodic solutions and small controls, we define an average control system that takes into account all possible variations of the control, and prove that its solutions approximate all solutions of the oscillating system as oscillations go faster. The dimension of its velocity set is characterized geometrically. When it is maximum the average system defines a Finsler metric, not twice differentiable in general. For minimum time control, this average system allows one to give a rigorous proof that averaging the Hamiltonian given by the maximum principle is a valid approximation.
AverageControlSystemV20.pdf (352.37 Ko) Télécharger le fichier
hal-00648330 , version 1 (05-12-2011)
hal-00648330 , version 2 (05-12-2011)
hal-00648330 , version 3 (10-09-2012)
hal-00648330 , version 4 (07-12-2012)
Alex Bombrun, Jean-Baptiste Pomet. The averaged control system of fast oscillating control systems. SIAM Journal on Control and Optimization, 2013, 51 (3), pp.2280-2305. ⟨10.1137/11085791X⟩. ⟨hal-00648330v4⟩
411 Consultations
372 Téléchargements
