s'authentifier
version française rss feed
hal-00652591, version 1
A visibility-based approach for occupancy grid computation in disparity space
Mathias Perrollaz () d1, John-David Yoder () a2, Amaury Negre (Auteur à contacter de préférence) b1, Anne Spalanzani c1, Christian Laugier () d1
N° RR-7841 (2011)
Résumé : Occupancy grids are a very convenient tool for environment representation in robotics. This paper will detail a novel approach to compute occupancy grids from stereo-vision, and shows its application for the field of intelligent vehicles. In the proposed approach, occupancy is initially computed directly in the stereoscopic sensor's disparity space. The calculation formally accounts for the detection of obstacles and road pixels in disparity space, as well as partial occlusions in the scene. In a second stage, this disparity-space occupancy grid is transformed into a Cartesian space occupancy grid to be used by subsequent applications. This transformation includes spatial and temporal filtering. The proposed method is designed to be easily processed in parallel. Consequently, we chose to implement it on GPU, which allows real-time processing for the demanding application. In this paper, we present this method and we propose an application to the problem of perception in a road environment. Results are presented with real road data, comparing qualitatively this approach with others.
  • Domaine : Informatique/Vision par ordinateur et reconnaissance de formes
  • Mots-clés : stereo-vision – occupancy grids – Intelligent Transportation Systems
  • Référence interne : RR-7841
  • hal-00652591, version 1
  • oai:hal.inria.fr:hal-00652591
  • Contributeur :
  • Soumis le : Jeudi 15 Décembre 2011, 20:03:05
  • Dernière modification le : Lundi 14 Janvier 2013, 11:25:17
tous les articles de la base du CCSd...
