Coupling particle sets of contours and streamline methods for solving convection problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics Letters Année : 2012
In this work a particle sets of contours method is coupled with a streamline technique in order to obtain accurate approximations of transport problems. A modified streamline technique is proposed and several bench tests arising in the field of porous media are then simulated to validate the new method.
hal-00653253 , version 1 (19-12-2011)
Héloïse Beaugendre, Serge Huberson, Iraj Mortazavi. Coupling particle sets of contours and streamline methods for solving convection problems. Applied Mathematics Letters, 2012, 25, pp.11-19. ⟨10.1016/j.aml.2011.06.031⟩. ⟨hal-00653253⟩
129 Consultations
0 Téléchargements
