Direct control based on sliding mode techniques for multicell serial chopper - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Series multi-cell converters introduced more than ten years ago provide many degrees of freedom like the possibility to distribute the voltage constraints among series-connected switches and to improve the output waveforms. Direct control laws make perfect use of them during transient behaviors, but leads to disorderly and imperfect steady-state operations. This paper deals with some solutions for the direct control of the voltages across the flying capacitors in the presence of fast variation of the input voltage by reach an optimal steady-state trajectory defined by the PWM control technique.
Automatique
ACC_11_AL_MG_JPB.pdf (996.64 Ko) Télécharger le fichier
hal-00654246 , version 1 (22-12-2011)
  • HAL Id : hal-00654246 , version 1
Leonardo Amet, Malek Ghanes, Jean-Pierre Barbot. Direct control based on sliding mode techniques for multicell serial chopper. IEEE ACC (American Control Conference), Jun 2011, San Francisco, United States. ⟨hal-00654246⟩
245 Consultations
308 Téléchargements
