Sensorless Fault Tolerant Control Based On Backstepping Strategy For Induction Motors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a fault tolerant control for induction motors based on backstepping strategy is designed. The proposed approach permits to compensate both the rotor resistance variations and the load torque disturbance. Moreover, to avoid the use of speed and ux sensors, a second order sliding mode observer is used to estimate the ux and the speed. The used observer converges in a nite time and permits to give a good estimate of ux and speed even in presence of rotor resistance variations and load torque disturbance. The simulation results show the e ciency of the proposed control scheme.
Automatique
IFAC_1943_FINAL.pdf (267.06 Ko) Télécharger le fichier
hal-00654250 , version 1 (21-12-2011)
  • HAL Id : hal-00654250 , version 1
Nadia Djeghali, Malek Ghanes, Jean-Pierre Barbot, Said Djennoune. Sensorless Fault Tolerant Control Based On Backstepping Strategy For Induction Motors. IFAC WC, Aug 2011, Milan, Italy. ⟨hal-00654250⟩
722 Consultations
396 Téléchargements
