Prehension movements in a patient (AC) with posterior parietal cortex damage and posterior callosal section. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Brain and Cognition Année : 2006
Prehension movements of the right hand were recorded in a right-handed man (AC), with an injury to the left posterior parietal cortex (PPC) and with a section of the left half of the splenium. The kinematic analysis of AC's grasping movements in direct and perturbed conditions was compared to that of five control subjects. A novel effect in prehension was revealed--a hemispace effect--in healthy controls only. Movements to the left hemispace were faster, longer, and with a smaller grasp aperture; perturbation of both object position and distance resulted in the attenuation of the direction effect on movement time and the time to velocity peak, with a reverse pattern in the time to maximum grip aperture. Nevertheless, the correlation between transport velocity amplitude and grasp aperture remained stable in both perturbed and non-perturbed movements, reflecting the coordination between reaching and grasping in control subjects. In contrast, transport and grasp, as well as their coordination in both direct and perturbed conditions, were negatively affected by the PPC and splenium lesion in AC, suggesting that transport and grasp rely on two functionally identifiable subsystems.
Neurosciences
hal-00654877 , version 1 (23-12-2011)
Victor Frak, Yves Paulignan, Marc Jeannerod, François Michel, Henri Cohen. Prehension movements in a patient (AC) with posterior parietal cortex damage and posterior callosal section.. Brain and Cognition, 2006, 60 (1), pp.43-8. ⟨10.1016/j.bandc.2005.09.010⟩. ⟨hal-00654877⟩
78 Consultations
0 Téléchargements
