s'authentifier
version française rss feed
hal-00655801, version 1
The 2011 Signal Separation Evaluation Campaign (SiSEC2011): - Biomedical data analysis -
Guido Nolte 1, Dominik Lutter 2, Andreas Ziehe 1, Francesco Nesta 3, Emmanuel Vincent () 4, Zbynek Koldovsky 5, Alexis Benichoux () 4, Shoko Araki 6
10th Int. Conf. on Latent Variable Analysis and Signal Separation (LVA/ICA) (2012) 423-429
Résumé : This paper summarizes the bio part of the 2011 community based Signal Separation Evaluation Campaign (SiSEC2011). Two different data sets were given. In the first task, participants were asked to estimate the causal relations of underlying sources from simulated bivariate EEG data. In the second task, participants were asked to reconstruct signaling pathways or parts of it from the microarray expression profi les. The results for each task were evaluated using di fferent objective performance criteria. We provide an overview of the biomedical datasets, tasks and criteria, and we report on the achieved results.
  • Domaine : Informatique/Traitement du signal et de l'image
    Sciences de l'ingénieur/Traitement du signal et de l'image
  • hal-00655801, version 1
  • oai:hal.inria.fr:hal-00655801
  • Contributeur :
  • Soumis le : Lundi 2 Janvier 2012, 15:08:02
  • Dernière modification le : Lundi 2 Avril 2012, 17:37:40
tous les articles de la base du CCSd...
