Constructing and Visualizing Chemical Reaction Networks from Pi-Calculus Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Formal Aspects of Computing Année : 2012
The pi-calculus, in particular its stochastic version the stochastic pi-calculus, is a common modeling formalism to concisely describe the chemical reactions occurring in biochemical systems. However, it remains largely unexplored how to transform a biochemical model expressed in the stochastic pi-calculus back into a set of meaningful reactions. To this end, we present a two step approach of first translating model states to reaction sets and then visualizing sequences of reaction sets, which are obtained from state trajectories, in terms of reaction networks. Our translation from model states to reaction sets is formally defined and shown to be correct, in the sense that it reflects the states and transitions as they are derived from the continuous time Markov chain-semantics of the stochastic pi-calculus. Our visualization concept combines high level measures of network complexity with interactive, table-based network visualizations. It directly reflects the structures introduced in the first step and allows modelers to explore the resulting simulation traces by providing both: an overview of a network's evolution and a detail inspection on demand.
main.pdf (2.07 Mo) Télécharger le fichier
hal-00656048 , version 1 (03-01-2012)
Mathias John, Hans-Jörg Schulz, Heidrun Schumann, Adelinde Uhrmacher, Andrea Unger. Constructing and Visualizing Chemical Reaction Networks from Pi-Calculus Models. Formal Aspects of Computing, 2012, ⟨10.1007/s00165-011-0209-0⟩. ⟨hal-00656048⟩
205 Consultations
351 Téléchargements
