A Spatial Extension to the Pi-Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Spatial dynamics receive increasing attention in Systems Biology and require suitable modeling and simulation approaches. So far, modeling formalisms have focused on population-based approaches or place and move individuals relative to each other in space. SpacePi extends the pi-calculus by time and space. pi processes are embedded into a vector space and move individually. Only processes that are sufficiently close can communicate. The operational semantics of SpacePi defines the interplay between movement, communication, and time-triggered events. A model describing the phototaxis of the Euglena micro-organism is presented as a practical example. The formalism's use and generality is discussed with respect to the modeling of molecular biological processes like diffusion, active transportation in cell signaling, and spatial structures.
final.pdf (373.39 Ko) Télécharger le fichier
hal-00656206 , version 1 (03-01-2012)
Mathias John, Roland Ewald, Adelinde Uhrmacher. A Spatial Extension to the Pi-Calculus. From Biology To Concurrency and back, Sep 2007, Lissabon, Portugal. ⟨10.1016/j.entcs.2007.12.010⟩. ⟨hal-00656206⟩
Collections
TDS-MACS
218 Consultations
306 Téléchargements
