The Non-Geek's Guide to the DAE Platform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Document Analysis and Exploitation platform is a sophisticated technical environment that consists of a repository containing document images, implementations of document analysis algorithms, and the results of these algo- rithms when applied to data in the repository. The use of a web- services model makes it possible to set up document analysis pipelines that form the basis for reproducible protocols. Since the platform keeps track of all intermediate results, it becomes an information resource for the analysis of experimental data. This paper provides a tutorial on how to get started using the platform. It covers the technical details needed to overcome the initial hurdles and have a productive experience with DAE.
DAS_2012.pdf (647.31 Ko) Télécharger le fichier
hal-00658281 , version 1 (10-04-2012)
Bart Lamiroy, Daniel Lopresti. The Non-Geek's Guide to the DAE Platform. DAS - 10th IAPR International Workshop on Document Analysis Systems, International Association for Pattern Recognition, Mar 2012, Gold Coast, Queensland, Australia. pp.27-32, ⟨10.1109/DAS.2012.87⟩. ⟨hal-00658281⟩
167 Consultations
252 Téléchargements
