s'authentifier
version française rss feed
hal-00659996, version 1
Principal Component Analysis for Interval-Valued Observations
Ahlame Douzal-Chouakria (Auteur à contacter de préférence) 1, Lynne Billard 2, Edwin Diday () 3
Statistical Analysis and Data Mining 4, 2 (2011) 229-246
Résumé : One feature of contemporary datasets is that instead of the single point value in the p-dimensional space p seen in classical data, the data may take interval values thus producing hypercubes in p. This paper studies the vertices principal components methodology for interval-valued data; and provides enhancements to allow for so-called 'trivial' intervals, and generalized weight functions. It also introduces the concept of vertex contributions to the underlying principal components, a concept not possible for classical data, but one which provides a visualization method that further aids in the interpretation of the methodology. The method is illustrated in a dataset using measurements of facial characteristics obtained from a study of face recognition patterns for surveillance purposes. A comparison with analyses in which classical surrogates replace the intervals, shows how the symbolic analysis gives more informative conclusions. A second example illustrates how the method can be applied even when the number of parameters exceeds the number of observations, as well as how uncertainty data can be accommodated.  2011 Wiley Periodicals, Inc. Statistical Analysis and Data Mining 4: 229-246, 2011
  • Domaine : Mathématiques/Statistiques
    Statistiques/Théorie
  • Mots-clés : ertices principal components – vertex contributions – correlations – inertia
  • hal-00659996, version 1
  • oai:hal.archives-ouvertes.fr:hal-00659996
  • Contributeur :
  • Soumis le : Mardi 13 Novembre 2012, 16:15:39
  • Dernière modification le : Mardi 13 Novembre 2012, 16:21:15
tous les articles de la base du CCSd...
