A new 3D-matching method of non-rigid and partially similar models using curve analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2011
Hedi Tabia
Mohamed Daoudi
Olivier Colot
The 3D-shape matching problem plays a crucial role in many applications such as indexing or modeling by example. Here, we present a novel approach to match 3D-objects in presence of non-rigid transformation and partially similar models. In this paper, we use the representation of surfaces by 3D-curves extracted around feature points. Indeed, surfaces are represented with a collection of closed curves and tools from shape analysis of curves are applied to analyze and to compare curves. The belief functions are used to define a global distance between 3D-objects. The experimental results obtained on the TOSCA and the SHREC07 datasets show that the system efficiently performs in retrieving similar 3D-models.
FINAL-ACCEPTED-tpami-2009-07-0448.R2_Tabia.pdf (1.07 Mo) Télécharger le fichier
hal-00660801 , version 1 (17-01-2012)
Hedi Tabia, Mohamed Daoudi, Jean-Philippe Vandeborre, Olivier Colot. A new 3D-matching method of non-rigid and partially similar models using curve analysis. IEEE Transactions on Pattern Analysis and Machine Intelligence, 2011, 33 (4), pp.852-858. ⟨10.1109/TPAMI.2010.202⟩. ⟨hal-00660801⟩
238 Consultations
596 Téléchargements
