CHOReOS Dynamic Development Model Definition (D2.1) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Marco Autili
  • Fonction : Auteur
  • PersonId : 854161
Davide Di Ruscio
  • Fonction : Auteur
  • PersonId : 863561
Inverardi Paola
  • Fonction : Auteur
  • PersonId : 875210
Tivoli Massimo
  • Fonction : Auteur
  • PersonId : 861036
Panos Vassiliadis
  • Fonction : Auteur
  • PersonId : 852921
James Lockerbie
  • Fonction : Auteur
  • PersonId : 909479
Neil Maiden
  • Fonction : Auteur
  • PersonId : 1362456
  • IdRef : 162073496
Darius Silingas
  • Fonction : Auteur
Marco Aurelio Gerosa
  • Fonction : Auteur
  • PersonId : 900046
Gustavo A Oliva
  • Fonction : Auteur
  • PersonId : 913261
Leonardo Leite
  • Fonction : Auteur
  • PersonId : 899307
The Future Internet envisions a ubiquitous world where available services can be easily discovered and coordinated so as to fit users needs. Service choreographies will play a central role in this vision as an effective means to allow heterogeneous services to suitably collaborate. This deliverable defines the CHOReOS Dynamic Development Process Model by refining and completing the artefacts/ activities and the relationships among them already sketched into the DoW (under the WP2 description), and conceptualized by the the CHOReOS conceptual model [CHO11b]. The process model is an abstract and simplified description of what will be the actual CHOReOS software development process to be defined at M24. The process model describes the "strategy" to be used during the choreography life cycle from design, to development, to maintenance (and hence from static, to runtime, to evolution). The model is made up of activities, common to (almost) every process, but structured in a particular way (i.e., the "CHOReOS way"), hence distinguishing the CHOReOS development process from others.
CHOReOSWP02D2.1CHOReOSDynamicDevelopmentModelDefinitionVA.0.pdf (4.81 Mo) Télécharger le fichier
hal-00664236 , version 1 (30-01-2012)
  • HAL Id : hal-00664236 , version 1
Marco Autili, Davide Di Ruscio, Inverardi Paola, Tivoli Massimo, Dionysis Athanasopoulos, et al.. CHOReOS Dynamic Development Model Definition (D2.1). 2011. ⟨hal-00664236⟩
195 Consultations
286 Téléchargements
