CHOReOS Requirements and scenarios for the "Passenger-friendly airport" (D6.1)
The purpose of this deliverable is to clarify the individual actions that take place among different actors of the "Passenger-friendly" scenario, as initially described in the DoW. People, services and Things interact with each other throughout the entire sequence of steps that compose the two distinct, but complementary, scenarios that support this specific use case of the CHOReOS project: "From planning to boarding" and "Bad weather at destination". This document also provides the domain requirements that have been elicited through a detailed requirement analysis of the scenarios. Finally, this deliverable presents a high-level overview of the choreographies that take place in the use case, for both scenarios.
Autre [cs.OH]
CHOReOSWP06D6.1RequirementsandscenariosforthePassengerfriendlyairportVA.pdf (3.94 Mo)
Télécharger le fichier
