On the Homogenization of some Non-coercive Hamilton-Jacobi-Isaacs Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
We study the homogenization of Hamilton-Jacobi equations with oscillating initial data and non-coercive Hamiltonian, mostly of the Bellman-Isaacs form arising in optimal control and differential games. We describe classes of equations for which pointwise homogenization fails for some data. We prove locally uniform homogenization for various Hamiltonians with some partial coercivity and some related restrictions on the oscillating variables, mostly motivated by the applications to differential games, in particular of pursuit-evasion type. The effective initial data are computed under some assumptions of asymptotic controllability of the underlying control system with two competing players.
BardiTerrone.pdf (438.05 Ko) Télécharger le fichier
hal-00664455 , version 1 (30-01-2012)
  • HAL Id : hal-00664455 , version 1
Martino Bardi, Gabriele Terrone. On the Homogenization of some Non-coercive Hamilton-Jacobi-Isaacs Equations. 2011. ⟨hal-00664455⟩
104 Consultations
140 Téléchargements
