Multi-Class Leveraged $k$-NN for Image Classification
The k-nearest neighbors (k-NN) classification rule is still an essential tool for computer vision applications, such as scene recognition. However, k-NN still features some major drawbacks, which mainly reside in the uniform voting among the nearest prototypes in the feature space. In this paper, we propose a new method that is able to learn the "relevance" of prototypes, thus classifying test data using a weighted k-NN rule. In particular, our algorithm, called Multi-class Leveraged k-nearest neighbor (MLNN), learns the prototype weights in a boosting framework, by minimizing a surrogate exponential risk over training data. We propose two main contributions for improving computational speed and accuracy. On the one hand, we implement learning in an inherently multiclass way, thus providing significant computation time reduction over one-versus-all approaches. Furthermore, the leveraging weights enable effective data selection, thus reducing the cost of k-NN search at classification time. On the other hand, we propose a kernel generalization of our approach to take into account real-valued similarities between data in the feature space, thus enabling more accurate estimation of the local class density. We tested MLNN on three datasets of natural images. Results show that MLNN significantly outperforms classic k-NN and weighted k-NN voting. Furthermore, using an adaptive Gaussian kernel provides significant performance improvement. Finally, the best results are obtained when using MLNN with an appropriate learned metric distance.
Traitement des images [eess.IV]
