Edge Extraction using Modulation and Demodulation: A Simple Technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Vinay Kumar
This paper discusses a simple but effective technique to extract edge information from an image. The method uses pulse amplitude modulation (PAM) together with differential phase shift keying (DPSK).
Image-Modulation.pdf (1.14 Mo) Télécharger le fichier
hal-00665006 , version 1 (01-02-2012)
  • HAL Id : hal-00665006 , version 1
Vinay Kumar, Dhawan Akshay. Edge Extraction using Modulation and Demodulation: A Simple Technique. [Research Report] 2012. ⟨hal-00665006⟩
Collections
LARA
81 Consultations
52 Téléchargements
