Elastic Shape Models for Face Analysis Using Curvilinear Coordinates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Imaging and Vision Année : 2009
This paper studies the problem of analyzing variability in shapes of facial surfaces using a Rie- mannian framework, a fundamental approach that allows for joint matchings, comparisons, and deformations of faces under a chosen metric. The starting point is to impose a curvilinear coordinate system, named the Darcyan coordinate system, on facial surfaces; it is based on the level curves of the surface distance function measured from the tip of the nose. Each facial surface is now represented as an indexed collection of these level curves. The task of finding optimal deformations, or geodesic paths, between facial surfaces reduces to that of finding geodesics between level curves, which is accomplished using the theory of elastic shape analy- sis of 3D curves. Elastic framework allows for nonlinear matching between curves and between points across curves. The resulting geodesics provide optimal elastic deformations between faces and an elastic metric for comparing facial shapes. We demonstrate this idea using examples from FSU face databas.
paper.pdf (6.18 Mo) Télécharger le fichier
hal-00665940 , version 1 (04-02-2012)
Anuj Srivastava, Chafik Samir, Shantanu H. Joshi, Mohamed Daoudi. Elastic Shape Models for Face Analysis Using Curvilinear Coordinates. Journal of Mathematical Imaging and Vision, 2009, 33 (2), pp.253-265. ⟨10.1007/s10851-008-0073-6⟩. ⟨hal-00665940⟩
255 Consultations
284 Téléchargements
