Non-rigid 3D shape classification using Bag-of-Feature techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Colot
Mohamed Daoudi
In this paper, we present a new method for 3D-shape categorization using Bag-of-Feature techniques (BoF). This method is based on vector quantization of invariant descriptors of 3D-object patches. We analyze the performance of two well-known classifiers: the Naïve Bayes and the SVM. The results show the effectiveness of our approach and prove that the method is robust to non-rigid and deformable shapes, in which the class of transformations may be very wide due to the capability of such shapes to bend and assume different forms.
tabiaICME2011.pdf (1.09 Mo) Télécharger le fichier
hal-00666732 , version 1 (06-02-2012)
  • HAL Id : hal-00666732 , version 1
Hedi Tabia, Olivier Colot, Mohamed Daoudi, Jean-Philippe Vandeborre. Non-rigid 3D shape classification using Bag-of-Feature techniques. IEEE International Conference on Multimedia and Expo (ICME), Jul 2011, Barcelona, Spain. pp.475. ⟨hal-00666732⟩
219 Consultations
259 Téléchargements
