Pose and Expression-Invariant 3D Face Recognition using Elastic Radial Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we explore the use of shapes of elastic radial curves to model 3D facial deformations, caused by changes in facial expressions. We represent facial surfaces by indexed collections of radial curves on them, emanating from the nose tips, and compare the facial shapes by comparing the shapes of their corresponding curves. Using a past approach on elastic shape analysis of curves, we obtain an algorithm for comparing facial surfaces. We also introduce a quality control module which allows our approach to be robust to pose variation and missing data. Comparative evaluation using a common experimental setup on GAVAB dataset, considered as the most expression-rich and noise-prone 3D face dataset, shows that our approach outperforms other state-of-the-art approaches.
BMVC_2010.pdf (3.38 Mo) Télécharger le fichier
hal-00667583 , version 1 (08-02-2012)
  • HAL Id : hal-00667583 , version 1
Hassen Drira, Boulbaba Ben Amor, Mohamed Daoudi, Anuj Srivastava. Pose and Expression-Invariant 3D Face Recognition using Elastic Radial Curves. British machine vision conference, Aug 2010, Aberystwyth, United Kingdom. pp.1-11. ⟨hal-00667583⟩
393 Consultations
537 Téléchargements
