3D-shape retrieval using curves and HMM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Colot
Mohamed Daoudi
In this paper, we propose a new approach for 3D-shape matching. This approach encloses an off-line step and an on-line step. In the off-line one, an alphabet, of which any shape can be composed, is constructed. First, 3D-objects are subdivided into a set of 3D-parts. The subdivision consists to extract from each object a set of feature points with associated curves. Then the whole set of 3D-parts is clustered into different classes from a semantic point of view. After that, each class is modeled by a Hidden Markov Model (HMM). The HMM, which represents a character in the alphabet, is trained using the set of curves corresponding to the class parts. Hence, any 3D-object can be represented by a set of characters. The on-line step consists to compare the set of characters representing the 3D-object query and that of each object in the given dataset. The experimental results obtained on the TOSCA dataset show that the system efficiently performs in retrieving similar 3D-models.
tabiaICPR2010.pdf (867.61 Ko) Télécharger le fichier
hal-00667989 , version 1 (08-02-2012)
  • HAL Id : hal-00667989 , version 1
Hedi Tabia, Olivier Colot, Mohamed Daoudi, Jean-Philippe Vandeborre. 3D-shape retrieval using curves and HMM. 20th IEEE International Conference on Pattern Recognition (ICPR 2010), Aug 2010, Istanbul, Turkey. pp.WeBCT9.6. ⟨hal-00667989⟩
202 Consultations
166 Téléchargements
