hal-00668921, version 1
Calibration of a fully-constrained parallel cable-driven robot
Julien Alexandre Dit Sandretto
a, 1David Daney
a, 1Marc Gouttefarde
2Cédric Baradat
b, 3
N° RR-7879 (2012)
Résumé : An identification of the model parameters for a parallel cable-driven robot is performed by using both a calibration and a self-calibration approach. The manipulator studied is based on a parallel architecture having 8 cables to control the 6 degrees of freedom of its mobile platform so that the mobile platform is fully constrained by the cables. Under some hypotheses on cable properties, the interest of redundancy in actuation is exploited to self-calibrate by using proprioceptive sensors. This approach is compared to the difficulties to implement a calibration process. Additionally, advanced tools and algorithmic improvements are presented to perform the parameter identification. A complete experimentation validates the robot accuracy improvement after calibration or self-calibration. We show that the basic hypotheses on cable properties are verified. Moreover, the investment in terms of time and cost to obtain the external measurements for calibration process does not bring better results and does not balance the simplicity and efficiency of the self calibration process.
- a – INRIA
- b – TECNALIA
- 1 : COPRIN (INRIA Sophia Antipolis)
- INRIA – Ecole des Ponts ParisTech
- 2 : Laboratoire d'Informatique de Robotique et de Microélectronique de Montpellier (LIRMM)
- CNRS : UMR5506 – Université Montpellier II - Sciences et Techniques du Languedoc
- 3 : TECNALIA France
- TECNALIA
- Domaine : Informatique/Robotique
- Mots-clés : Calibration – Cable-driven Robot – kinematics
- Référence interne : RR-7879
- hal-00668921, version 1
- http://hal.inria.fr/hal-00668921
- oai:hal.inria.fr:hal-00668921
- Contributeur : Julien Alexandre Dit Sandretto
- Soumis le : Vendredi 10 Février 2012, 16:30:15
- Dernière modification le : Mardi 17 Avril 2012, 15:21:48
Documents associés
Exporter
