Robust Module-based Data Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Knowledge and Data Engineering Année : 2013
The current trend for building an ontology-based data management system (DMS) is to capitalize on efforts made to design a preexisting well-established DMS (a reference system). The method amounts to extracting from the reference DMS a piece of schema relevant to the new application needs -- a module --, possibly personalizing it with extra-constraints wrt the application under construction, and then managing a dataset using the resulting schema. In this paper, we extend the existing definitions of modules and we introduce novel properties of robustness that provide means for checking easily that a robust module-based DMS evolves safely wrt both the schema and the data of the reference DMS. We carry out our investigations in the setting of description logics which underlie modern ontology languages, like RDFS, OWL, and OWL2 from W3C. Notably, we focus on the DL-lite_A dialect of the DL-lite family, which encompasses the foundations of the QL profile of OWL2 (ie DL-lite_R): the W3C recommendation for efficiently managing large datasets.
tkde-2012.pdf (512.37 Ko) Télécharger le fichier
hal-00671004 , version 1 (16-02-2012)
François Goasdoué, Marie-Christine Rousset. Robust Module-based Data Management. IEEE Transactions on Knowledge and Data Engineering, 2013, Transactions on Knowledge and Data Engineering, 25 (3), pp.648-661. ⟨10.1109/TKDE.2011.255⟩. ⟨hal-00671004⟩
402 Consultations
455 Téléchargements
