A zero knowledge identification scheme based on the q-ary SD problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
At CRYPTO'93, Stern proposed a 3-pass code-based identification scheme with a cheating probability of 2/3. In this paper, we propose a 5-pass code-based protocol with a lower communication complexity, allowing an impersonator to succeed with only a probability of 1/2. Furthermore, we propose to use double-circulant construction in order to dramatically reduce the size of the public key. The proposed scheme is zero-knowledge and relies on an NP-complete coding theory problem (namely the q-ary Syndrome Decoding problem). The parameters we suggest for the instantiation of this scheme take into account a recent study of (a generalization of) Stern's information set decoding algorithm, applicable to linear codes over arbitrary fields Fq; the public data of our construction is then 4 Kbytes, whereas that of Stern's scheme is 15 Kbytes for the same level of security. This provides a very practical identification scheme which is especially attractive for light-weight cryptography.
zkqsd.pdf (283.97 Ko) Télécharger le fichier
hal-00674249 , version 1 (20-03-2012)
Pierre-Louis Cayrel, Pascal Véron, Sidi Mohamed El Yousfi Alaoui. A zero knowledge identification scheme based on the q-ary SD problem. Selected Areas in Cryptography, Aug 2010, Waterloo, Canada. pp.171-186, ⟨10.1007/978-3-642-19574-7_12⟩. ⟨hal-00674249⟩
215 Consultations
1053 Téléchargements
