Controllability of 3D low Reynolds swimmers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2014
In this article, we consider a swimmer (i.e. a self-deformable body) immersed in a fluid, the flow of which is governed by the stationary Stokes equations. This model is relevant for studying the locomotion of microorganisms or micro robots for which the inertia effects can be neglected. Our first main contribution is to prove that any such microswimmer has the ability to track, by performing a sequence of shape changes, any given trajectory in the fluid. We show that, in addition, this can be done by means of arbitrarily small body deformations that can be superimposed to any preassigned sequence of macro shape changes. Our second contribution is to prove that, when no macro deformations are prescribed, tracking is generically possible by means of shape changes obtained as a suitable combination of only four elementary deformations. Eventually, still considering finite dimensional deformations, we state results about the existence of optimal swimming strategies for a wide class of cost functionals.
generic_control_3D_microswimmers4.pdf (556.26 Ko) Télécharger le fichier
hal-00674430 , version 1 (27-02-2012)
Paternité
Jérôme Lohéac, Alexandre Munnier. Controllability of 3D low Reynolds swimmers. ESAIM: Control, Optimisation and Calculus of Variations, 2014, 20 (1), pp.236--268. ⟨10.1051/cocv/2013063⟩. ⟨hal-00674430⟩
548 Consultations
153 Téléchargements
