Quasi-periodic solutions of the 2D Euler equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asymptotic Analysis Année : 2013
We consider the two-dimensional Euler equation with periodic boundary conditions. We construct time quasi-periodic solutions of this equation made of localized travelling profiles with compact support propagating over a stationary state depending on only one variable. The direction of propagation is orthogonal to this variable, and the support is concentrated on flat strips of the stationary state. The frequencies of the solution are given by the locally constant velocities associated with the stationary state.
qpeuler.pdf (77.09 Ko) Télécharger le fichier
hal-00678848 , version 1 (14-03-2012)
Nicolas Crouseilles, Erwan Faou. Quasi-periodic solutions of the 2D Euler equation. Asymptotic Analysis, 2013, 81 (1), pp.31-34. ⟨10.3233/ASY-2012-1117⟩. ⟨hal-00678848⟩
223 Consultations
176 Téléchargements
