Materialized View Selection for XQuery Workloads - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The efficient processing of XQuery still poses significant challenges. A particularly effective technique to improve XQuery processing performance consists of using materialized views to answer queries. In this work, we consider the problem of choosing the best views to materialize within a given space budget in order to improve the performance of a query workload. The paper is the first to address the view selection problem for queries and views with value joins and multiple return nodes. The challenges we face stem from the expressive power and features of both the query and view languages and from the size of the search space of candidate views to materialize. While the general problem has prohibitive complexity, we propose and study a heuristic algorithm and demonstrate its superior performance compared to the state of the art.
paper.pdf (367.67 Ko) Télécharger le fichier
hal-00680365 , version 1 (19-03-2012)
hal-00680365 , version 2 (13-06-2012)
  • HAL Id : hal-00680365 , version 2
Asterios Katsifodimos, Ioana Manolescu, Vasilis Vassalos. Materialized View Selection for XQuery Workloads. SIGMOD - ACM SIGMOD International Conference on Management of Data 2012, May 2012, Scottsdale, Arizona, United States. ⟨hal-00680365v2⟩
348 Consultations
674 Téléchargements
