True Dimension of Some Quadratic Binary Trace Goppa Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Designs, Codes and Cryptography Année : 2001
We compute in this paper the true dimension over F2 of Goppa Codes g(z)=TrF22s:F2s(z) proving, this way, a conjecture stated in [14,16].
true_dim_trace_goppa_codes.pdf (223.4 Ko) Télécharger le fichier
hal-00680454 , version 1 (20-03-2012)
Pascal Véron. True Dimension of Some Quadratic Binary Trace Goppa Codes. Designs, Codes and Cryptography, 2001, 24 (1), pp.81-97. ⟨10.1023/A:1011281431366⟩. ⟨hal-00680454⟩
Collections
UNIV-TLN IMATH
65 Consultations
198 Téléchargements
