Discharging Proof Obligations from Atelier B using Multiple Automated Provers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a method to discharge proof obligations from Atelier B using multiple SMT solvers. It is based on a faithful modeling of B's set theory into polymorphic first-order logic. We report on two case studies demonstrating a significant improvement in the ratio of obligations that are automatically discharged.
main.pdf (388.34 Ko) Télécharger le fichier
hal-00681781 , version 1 (22-03-2012)
  • HAL Id : hal-00681781 , version 1
David Mentré, Claude Marché, Jean-Christophe Filliâtre, Masashi Asuka. Discharging Proof Obligations from Atelier B using Multiple Automated Provers. ABZ - 3rd International Conference on Abstract State Machines, Alloy, B and Z, Jun 2012, Pisa, Italy. ⟨hal-00681781⟩
1221 Consultations
329 Téléchargements
