On the Well-Posedness , Stability And Accuracy Of An Asymptotic Model For Thin Periodic Interfaces In Electromagnetic Scattering Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2013
We analyze the well-posedness and stability properties of a parameter dependent problem that models the reflection and transmission of electromagnetic waves at a thin and rapidly oscillating interface. The latter is modeled using approximate interface conditions that can be derived using asymptotic expansion of the exact solution with respect to the small parameter (proportional to the periodicity length of oscillations and the width of the interface). The obtained uniform stability results are then used to analyze the accuracy (with respect to the small parameter) of the proposed model.
DeHaJo-2-hal.pdf (474.1 Ko) Télécharger le fichier
hal-00682357 , version 1 (26-03-2012)
  • HAL Id : hal-00682357 , version 1
Bérangère Delourme, Houssem Haddar, Patrick Joly. On the Well-Posedness , Stability And Accuracy Of An Asymptotic Model For Thin Periodic Interfaces In Electromagnetic Scattering Problems. Mathematical Models and Methods in Applied Sciences, 2013. ⟨hal-00682357⟩
333 Consultations
447 Téléchargements
