$H_{\infty}$ Robust Control Design for Teleoperation Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the problem of delay-dependent robust $H_{\infty}$ control for time-varying delay teleoperation system with norm-bounded and time-varying model uncertainties. Thanks to our proposed control scheme, Lyapunov-Krasovskii functionals (LKF) and $H_{\infty}$ theory, the delay-dependent stability and tracking performance analysis are proposed in terms of Linear Matrix Inequality (LMI) optimization. An illustrative example is given by various simulations to prove that, our proposed solution is efficient to handle time-varying delays and uncertainties under different working conditions, such as abrupt tracking and wall contact motion.
uncertainties.pdf (584.83 Ko) Télécharger le fichier
hal-00682948 , version 1 (27-03-2012)
  • HAL Id : hal-00682948 , version 1
Bo Zhang, Alexandre Kruszewski, Jean-Pierre Richard. $H_{\infty}$ Robust Control Design for Teleoperation Systems. 7th IFAC Symposium on Robust Control Design, Jun 2012, Aalborg, Denmark. ⟨hal-00682948⟩
400 Consultations
169 Téléchargements
