CLASSY: a Clock Analysis System for Rapid Prototyping of Embedded Applications on MPSoCs
This paper presents an abstract clock-based reasoning for the rapid prototyping of embedded applications executed on multiprocessor systems-on-chip (MPSoCs). In this framework, a synchronous multi-clock modeling of application behaviors is considered. The scheduling of these applications on execution platforms composed of processors operating at various frequencies is described and analyzed with the proposed clock modeling. As in the static scheduling of synchronous dataflows (SDFs), requirements for admissible schedules are investigated, which come not only from expected application behavior, but also from execution platform properties. An algorithm is proposed to construct admissible schedules respecting the identified requirements. It is then adapted to support the synthesis of admissible schedules for adaptive system behaviors including, e.g., dynamic frequency changing or task migration. The modeling, analysis and algorithms presented in this paper have been implemented in a prototype tool named CLASSY (standing for CLock AnalySis SYstem), providing also a way to visualize design results. The proposed approach provides a fast and cost-effective means to define correct-by-construction systems and simplify the design space exploration of complex embedded systems.
Ce rapport présente un raisonnement à base d'horloges abstraites pour le prototypage rapide d'applications embarquées sur des systèmes-sur-puce multiprocesseurs (en anglais, multiprocessor system-on-chip -- MPSoCs). Dans ce cadre, une modélisation synchrone multi-horloge des comportements d'applications est considérée. L'ordonnancement de ces applications sur des plates-formes d'exécution composées de processeurs fonctionnant à des fréquences différentes est décrit et analysé à l'aide d'horloges. Comme dans l'ordonnancement statique de spécifications flot de données synchrones, des critères d'admissibilité doivent être satisfaits non seulement par les comportements des applications, mais aussi par ceux des plates-formes d'exécution. Un algorithme est proposé pour construire des ordonnancements admissibles respectant les critères identifiés. Il est ensuite adapté pour supporter la synthèse d'ordonnancements admissibles pour comportements adaptatifs, incluant par exemple, des changements dynamiques de fréquences ou des migrations de tâches. La modélisation, l'analyse et les algorithmes présentés dans ce rapport ont été mis en oeuvre dans un prototype d'outil nommé CLASSY (pour CLock AnalySis SYstem), fournissant également un moyen de visualiser les résultats. Notre approche fournit un moyen rapide et peu coûteux pour définir des systèmes corrects-par-construction et simplifier l'exploration de l'espace de conception pour systèmes embarqués complexes.
