$H_{\infty}$ Control of Delayed Teleoperation Systems under Polytopic-Type Uncertainties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, the $H_{\infty}$ control design under time-varying delays and polytopic-type uncertainties, which ensures the stability and performance (synchronization/transparency) between the master and slave manipulators, is proposed. With this objective, the design of the controller based on our proposed control scheme is performed by using Linear Matrix Inequality (LMI) optimization based on Lyapunov-Krasovskii functionals (LKF) and $H_{\infty}$ control theory. The solution is efficient for different working conditions, \emph{e.g.} abrupt tracking and wall contact motion, and this is illustrated by a final example.
polytopique-MED.pdf (581.63 Ko) Télécharger le fichier
hal-00684710 , version 1 (02-04-2012)
  • HAL Id : hal-00684710 , version 1
Bo Zhang, Alexandre Kruszewski, Jean-Pierre Richard. $H_{\infty}$ Control of Delayed Teleoperation Systems under Polytopic-Type Uncertainties. 20th Mediterranean Conference on Control and Automation, Jul 2012, Barcelone, Spain. ⟨hal-00684710⟩
246 Consultations
79 Téléchargements
