An Efficient Hybrid P2P Approach for Non-redundant Tree Exploration in B&B Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The branch and bound (B&B) algorithm is one of the most used methods to solve in an exact way combinatorial optimization problems. In a previous article, we proposed a new approach of the parallel B&B algorithm for distributed systems using the farmer-worker paradigm. However, the new farmer-worker approach has a disadvantage: some nodes of the B&B tree can be explored by several B&B processes. To prevent this redundant work and speed up, we propose a new P2P approach inspired from the strategies of existing P2P systems like Napster and JXTA. Validation is performed by experimenting the two approaches on mono-objective flow-shop problem instances using 500 processors belonging to the French national grid, Grid'5000. The obtained results prove the efficiency of the proposed P2P approach. Indeed, the execution time obtained with the P2P version, even if more communicative, is better than the farmer-worker's one.
Autre [cs.OH]
Fichier non déposé
hal-00684915 , version 1 (03-04-2012)
Malika Mehdi, Mohand Mezmaz, Nouredine Melab, El-Ghazali Talbi, Pascal Bouvry. An Efficient Hybrid P2P Approach for Non-redundant Tree Exploration in B&B Algorithms. IEEE Proceedings of International Workshop on P2P, Parallel, Grid and Internet Computing (In conj. with Complex, Intelligent and Software Intensive Systems, CISIS2008), Mar 2008, Barcelona, Spain. ⟨10.1109/CISIS.2008.64⟩. ⟨hal-00684915⟩
72 Consultations
0 Téléchargements
