Online multipath convolutional coding for real-time transmission - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Online multipath convolutional coding for real-time transmission Année : 2012
Tuan Tran Thai
  • Fonction : Auteur
  • PersonId : 923345
Emmanuel Lochin
Jérôme Lacan
  • Fonction : Auteur
  • PersonId : 944205
Most of multipath multimedia streaming proposals use Forward Error Correction (FEC) approach to protect from packet losses. However, FEC does not sustain well burst of losses even when packets from a given FEC block are spread over multiple paths. In this article, we propose an online multipath convolutional coding for real-time multipath streaming based on an on-the-fly coding scheme called Tetrys. We evaluate the benefits brought out by this coding scheme inside an existing FEC multipath load splitting proposal known as Encoded Multipath Streaming (EMS). We demonstrate that Tetrys consistently outperforms FEC in both uniform and burst losses with EMS scheme. We also propose a modification of the standard EMS algorithm that greatly improves the performance in terms of packet recovery. Finally, we analyze different spreading policies of the Tetrys redundancy traffic between available paths and observe that the longer propagation delay path should be preferably used to carry repair packets.
multipath.pdf (109.88 Ko) Télécharger le fichier
hal-00684956 , version 1 (05-04-2012)
Tuan Tran Thai, Emmanuel Lochin, Jérôme Lacan. Online multipath convolutional coding for real-time transmission. 19th International Packet Video Workshop, May 2012, Munich-Garching, Germany. ⟨hal-00684956⟩
Collections
ARSSO ANR
85 Consultations
120 Téléchargements
