Algebraic parameter estimation of a biased sinusoidal waveform signal from noisy data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The amplitude, frequency and phase of a biased and noisy sum of two complex exponential sinusoidal signals are estimated via new algebraic techniques providing a robust estimation within a fraction of the signal period. The methods that are popular today do not seem able to achieve such performances. The efficiency of our approach is illustrated by several computer simulations.
final-version-sysid2012.pdf (218.76 Ko) Télécharger le fichier
hal-00685067 , version 1 (03-04-2012)
  • HAL Id : hal-00685067 , version 1
Rosane Ushirobira, Wilfrid Perruquetti, Mamadou Mboup, Michel Fliess. Algebraic parameter estimation of a biased sinusoidal waveform signal from noisy data. Sysid 2012, 16th IFAC Symposium on System Identification, Jul 2012, Brussels, Belgium. ⟨hal-00685067⟩
384 Consultations
609 Téléchargements
