Parameter estimation of permanent magnet stepper motors without position or velocity sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper presents a new sensorless parameter identification method for permanent magnet stepper motors. Current sensors are assumed available, but position and velocity sensors are not. Data is obtained with open-loop voltage com- mands at multiple speeds. A new reference frame is proposed that presents advantages similar to the standard d − q frame, but without the need for a position sensor. The method exploits carefully derived linear parameterizations and a least-squares algorithm. In one case, overparameterization is resolved using elimination theory. Overall, the parameters identified using the new procedure are found to be very close to those obtained with position sensors. The approach is potentially applicable to other types of synchronous motors as well.
v120308.pdf (189.19 Ko) Télécharger le fichier
hal-00686349 , version 1 (10-04-2012)
  • HAL Id : hal-00686349 , version 1
Romain Delpoux, Marc Bodson, Thierry Floquet. Parameter estimation of permanent magnet stepper motors without position or velocity sensors. American Control Conference, Jun 2012, Montreal, Canada. ⟨hal-00686349⟩
277 Consultations
854 Téléchargements
